Errror 'DBASE writer: 'unknown' is not recognized as a valid encoding name'.
  • February 14, 2024
  • 126 views
peter100
Cache problem?
At writing a dbf-file happens errror "DBASE writer: 'unknown' is not recognized as a valid encoding name".
  • FME(R) 2023.2.0.0 (20231201 - Build 23764 - WIN64)
  • Error happens since today
  • Feature Caching set off
  • Result files: .cpg, .dbf, ‘.dbt’
  • Each process creates 51 files of altogether 283 --> maybe a caching problem?
  • Same error happens also with DBASE writer -> character encoding 'utf-8'
Reader file:
xlsx-file (MS Office 2016)
Writer dBase (DBF) with character encoding Latin-1 Western European (iso8859-1)
  • Parameter tab --> Name-table "JPB_NR" (format: number(3,0)
  • all together 283 lines of data
DBASE writer:
  • Writing files using character encoding 'iso-8859-1'
  • OS Locale Encoding : windows-1252
  • Process Encoding   : UTF-8
Test files are in attachments.
Can anybody help?
Regards,
Steffen P.
virtualcitymatt
Forum|alt.badge.img+47
OK i took a look and saw something else - I indeed got the same ERROR but what I also noticed was the following line in the log:
“dBASE Writer: Maximum number of open output files reached, caching additional features until end of translation.”
I noticed that the job was able to write out 51 files fine - but as soon as trying the 52nd file then it would ERROR. I couldn’t tell you why.
What did work though was if I swapped out the Writer for a FeatureWriter and then used the GroupBy inside of it and made sure my groups were only 50 features big.
peter100
  • February 15, 2024
Hi Matt,
thanks for your workaround. Is the GroupCounter your own transformer? He don’t exist at my end. How can I create it / rebuild?
I tested with other character encodings, e.g. Latin 2 Western European. It worked fine.
Regards
virtualcitymatt
Oh - It’s just a custom transformer from FME Hub: GroupCounter | FME Hub (safe.com)
you can essentially swap it out for a ModuloConter if you wanted. The GroupCounter is just little nicer because the groups are ordered.
Yes I do think it’s a bug somewhere because it seems like it’s trying to work around it - so somewhere in that workaround process I guess FME is hitting a bug. It’s worth submitting this to Safe Software support to get them to fix the bug for future releases.
