I would like to join 3 spatial table from oracle spatial database. I use Joiner to create relation between tables. Each table has geometry, I would like to save each of this geometry in separate column in xml. How to map geometry column in oracle spatial reder.I use SeabedML (GML) as writer.
Handle mulity geometry columns in oracel spatial
