Remove excess vertices on line segments without changing the shape.
  • March 21, 2019
  • 523 views
cshir065
I have a large dataset of line segments, which are both curved and straight. The problem is, some of the lines have hundreds (possibly thousands) of vertices. I would like to remove enough vertices without affecting the shape of the line. What is the best way to do this?
Best answer by ebygomm
The Generalizer will remove colinear points from lines - you'll probably want one of the generalizing algorithms if the aim is just to reduce the density of points
Forum|alt.badge.img+46
  • March 21, 2019
cshir065
  • April 23, 2019
Thanks, I tried this and it worked really well. The 'Thin No Point' algorithm did not change the shape of line with a low generalizing tolerance!
