Updating multiple occurrences of an XML element
  • July 13, 2023
  • 28 views
babar_ali99
<mdContact>
<rpOrgName>AAA</rpOrgName>
<rpPosName>BBB</rpPosName>
rpOrgName is appearing at multiple locations in the XML file.
How can I update its value from AAA to CCC for all of them in a single go without having to go to each element using Xpath.
geomancer
Forum|alt.badge.img+60
  • July 13, 2023
One possible way would be to read the xml as a text file with parameter Read Whole File at Once set to 'Yes'. Use a StringReplacer to change all occurences of <rpOrgName>AAA</rpOrgName> with <rpOrgName>CCC</rpOrgName>, and write the results to a text file with extension xml.
