How do I fix polygon features so they aren't rejected from the Point On Area Overlayer Transformer?
  • August 4, 2023
  • 172 views
kmc5678
I have a polygonal tax lot feature class where about half of the features are being rejected from the Point On Area Overlayer Transformer with a rejection code of "INVALID_POLYGON_GEOMETRY_VERTICES". How do I fix these so they are recognized by the transformer?Point On Area Overlayer parametersScreenshot 2023-08-04 111712Screenshot 2023-08-04 111645
Best answer by redgeographics
You can try running them through the GeometryValidator before the PointOnAreaOverlayer. Probably the OGC Compliant and OGC Simple tests would be good to try first and see what that does.
When you inspect those rejected features, do you notice anything odd about them?
Forum|alt.badge.img+62
  • August 4, 2023
kmc5678
  • August 8, 2023
Thanks for the suggestion @Hans van der Maarel​. This seems to have worked! Interestingly all of the features passed the validator and no repairs were performed. I guess this transformer truly can just validate a geometry even if it doesn't repair anything? Thanks again.
