How do I join a CSV to an Esri feature class in an oracle dB and write out the matched records to a feature class in a file geodatabase on my local machine?
  • May 24, 2023
  • 6 replies
  • 47 views
kmc5678
I'm currently using a CSV reader, Database Joiner and ESRI Geodatabase Writer. The join is working perfectly: Screenshot 2023-05-24 141658
But when I connect the joined output to the geodatabase writer no records are written to the feature class in the file gdb and I get an error saying "Cannot write a non-area feature to an area feature class": Screenshot 2023-05-24 152920I have tried both Drop and Create and Truncate Existing for Table Handling.
Screenshot 2023-05-24 153145Any suggestions are greatly appreciated.
Best answer by hkingsbury
Sorry for the confusion, Yes I'd like the output to be spatial. The dataset I'm joining the CSV to is a polygonal feature class in an oracle enterprise database. I want to join the matching record's attributes of the CSV to an existing buildings dataset and export to a file geodatabase on my local machine.
Is the geometry coming through encoded in an attribute? If it is, you'll need to use a geometryreplacer to turn it spatial.
If its not coming through at all with the databasejoiner, you might need to look at using an oracle reader and join the data with a featuremerger or featurejoiner
hkingsbury
Forum|alt.badge.img+67
  • May 24, 2023
You're trying to write non spatial features to a spatial (polygon) layer.
You'll need to change the Geometry in your writer to "Table"
kmc5678
  • May 24, 2023
Thanks for your response hkingsbury. Changing to "Table" creates a fgdb table. How do I create a feature class?
hkingsbury
  • May 24, 2023
A table is a type of feature class. Are you expecting the data to be spatial? In its current form there is no geometry on the feature to make it spatial
kmc5678
  • May 24, 2023
hkingsbury
  • May 24, 2023
kmc5678
  • May 24, 2023
This was the issue! The geometry wasn't coming through with databasejoiner. I used an oracle spatial reader and fed both datasets into Featurejoiner and was able to write out a polygonal feature class! Thanks so much hkingsbury I really appreciate the help.
