Hello everyone!I am new in Java programing.How can i pull out attributes for each object Person from this String?Also date must be formatted in for example "05.05.1988".How?
  • February 5, 2019
  • 38 views
String text = "John.Davidson/05051988/Belgrade Michael.Barton/01011968/Krakov Ivan.Perkinson/23051986/Moscow";
Best answer by chrisatsafe
Hi @nenicstefan,
This task can be broken down into 3 sections.
Step 1 - Separate Features
In order to separate the attributes, you will first have to separate your features. You can accomplish this using an AttributeSplitter and setting the delimiter to " " (single space). Next, your features will be stored in a list which should be exploded by a ListExploder.
Using the sample text string you provided, the output of the ListExploder will be 3 features that are formatted as follows:
Step 2 - Separate Attributes
Use a second AttributeSplitter to separate attributes by the "/" delimiter. Next, use an AttributeManager to create attribute names, assign attribute values from the list created by the second AttributeSplitter, and remove unwanted attributes.
Note: if you want to replace the space between first and last name, you can use a StringReplacer to replace the "." with " " (space).
Step 3 - Format the Date
The final step is to use a DateTimeConverter to format the date in your preferred format. In this case, you should specify the input format
%d%m%Y
and Output Format:
%d.%m.%Y
This should leave you with a workspace that looks something like this:0684Q00000ArJqWQAV.png
Output
Helpful Resources:
chrisatsafe
  • February 5, 2019
Hi @nenicstefan,
%d%m%Y
and Output Format:
%d.%m.%Y
Output
Helpful Resources:
philippeb
Forum|alt.badge.img+22
  • February 5, 2019
Use AttributeSplitter with / in delimeter and after
Use DateTimeConverter with _list{1}, _list{4}, _list{6} and Outpurt Format with %d.%m.%Y
