Has anyone worked with spatial indexing using GDB/SDE as output format? The spatial indexing function only appears for SQL Spatial formats. Any response is very much appreciated. Thank you!
  • May 26, 2023
  • 14 views
sam.cortero
Participant
evieatsafe
Forum|alt.badge.img+20
  • May 29, 2023
Hi @sam.cortero​ this seems to be a general question, you may want to be more specific with what you are trying to do. What format of data are you reading or writing from in FME to GDB? Could you share some screenshots, your workspace, or some sample data?
For some general information, here are some existing articles that deal with GDB/SDE and spatial indexes:
