Hi, I'm trying to use the attribute manager to replace all instances of double quote marks " with single quote marks ' for the values of the attribute 'testo' @ReplaceRegularExpression(@Value(testo),",') I can replace letters ok, but not quotes.
  • December 20, 2022
  • 5 replies
  • 357 views
Best answer by nielsgerrits
This works for me, in fme 2021.2:
@ReplaceString(@Value(testo),"\"",',caseSensitive=TRUE)
Please note that the field Attribute Value in the AttributeManager turns red, indicating something is off, but it does work fine.
2022-12-20_14h35_47
nielsgerrits
Forum|alt.badge.img+64
  • December 20, 2022
2022-12-20_14h35_47
dustin
Forum|alt.badge.img+31
  • December 20, 2022
2022-12-20_14h35_47
@nielsgerrits​ Just curious, does 2021.2 make the attribute value parameter red with this input? It works in 2022.1 also, but it's red.image
nielsgerrits
Aye, it does. Looks like a glitch to me in the value validation. I'll create a ticket.
  • December 20, 2022
@nielsgerrits​ thank you so much. i was trying so many different things. i don't think the red flagged parameter was helping my attempts because i was just modifying it each time i saw that.
danminneyatsaf
Forum|alt.badge.img+13
Looks like this is related to the quote (") character being present within a formula. This doesn't have an effect on the functionality of the workspace but we will try to resolve this as soon as possible. The ticket number for this is FMEDESKTOP-13584.
We will update this community post when a fix is released. Thanks all!
