Hi. I would like to know how to add off set value of location into the workspace. I have an workspace to convert file from .Rvt to .tileset (.b3dm) and .Geojson.
  • October 17, 2022
  • 29 views
Coordinate system setter is in the workspace, so I can select local coordinate, but I want to add offset value in somewhere in the workspace. Please kindly let me know how to add off set value (Latitude shift, Longitude shift, and height shift). Thank you.
nielsgerrits
Forum|alt.badge.img+64
You can do this with the Offsetter transformer.
  • October 17, 2022
Thanks!
