Sorry, I'm new to FME and don't know which transformer to use. I am working on an FME project that is currently getting an XML response using an HTTPCaller.
The Output of the HTTPCaller has many "attributes" and then the Output is passed to an XML Fragmenter. The XML Fragmenter output is the same but has one new attribute pulled from the XML response. It then is passed to an XMLQueryExtractor which then adds another attribute.
I need to get the value of a tag and I'm wondering if I should add an XML Flattener or Fragmenter or perform this in the XML Query Extractor or some other transformer.
an example of what I need is the value in <sub3> in the following XML example and save it to a variable for later use.
<Root><sub1><sub2><sub3>value</sub3></sub2></sub1></root>
Thank you
