When the FTPCaller Transformer uploads a file, is there a way to set a parameter where when it uploads the file it actually moves the file out of the source folder and not copy the file?
Page 1 / 1
In short, no.
To achieve that, you'll want to delete the file after its been uploaded. You can use the filecopy writer to achieve this
https://community.safe.com/s/question/0D54Q000080hRpdSAE/file-copy-delete
