How can I get the straight (and predominant) line from a polygon?
  • October 14, 2022
  • 60 views
input_outputI would like to get the predominant line for each polygon. I have tried using the 'CenterlineReplacer' but that doesn't work well since a lot of these shapes aren't long and narrow areas.
I only need one line per polygon, but it needs to be straight. The length of the line doesn't matter. I'm interested in the direction.
Does anyone have an idea about how I can approach this task?
Best answer by markatsafe
@nibon​ BoundingBoxReplacer has a 2D Oriented Bounding Box that might give you the result you need, depending on the nature of your areas. You can then pickout the centerline of the bounding box.
  • October 14, 2022
danilo_fme
Forum|alt.badge.img+52
  • October 14, 2022
great solution!
