FeatureReader reading fmw file - read Scripting / startup python script
  • January 10, 2024
  • 6 replies
  • 138 views
asablomberg
Forum|alt.badge.img+8
I have a workspace that reads other workspaces, to do an inventory. I have looked for the Startup Python Script but I can't find it, does the FeatureReader not read that information?
Best answer by david_r
@nielsgerrits​ is right, unfortunately the FMW reader does not return the startup or shutdown script. You have to read the .fmw file as a text file and look for lines starting with either FME_BEGIN_PYTHON or FME_END_PYTHON.
For decoding, you should use the following from the fmeobjects module:
decoded_str = fmeobjects.FMESession().decodeFromFMEParsableText(encoded_str)
 While you're at it, you might also be interested in looking for a line that contains "PYTHON_COMPATIBILITY=" to complete your inventory.
nielsgerrits
Forum|alt.badge.img+64
You can read the .fmw as text. Look for FME_BEGIN_PYTHON / FME_END_PYTHON. You will need to decode the string.
  • January 10, 2024
nielsgerrits
Nooooooo David I almost had it solved myself 😞 🙂
I was already puzzled why I had to first HTML decode and then FME decode it. Thanks for pointing this out. (But why is it also in the "#!  BEGIN_PYTHON" row?)
This works:
import fme
import fmeobjects
class FeatureProcessor(object):
    def __init__(self):
        pass
    def has_support_for(self, support_type: int):
        return support_type == fmeobjects.FME_SUPPORT_FEATURE_TABLE_SHIM
    def input(self, feature: fmeobjects.FMEFeature):
        parsed_string = fmeobjects.FMESession().decodeFromFMEParsableText(feature.getAttribute('text_line_data'))
        feature.setAttribute('text_line_data', parsed_string)
        self.pyoutput(feature)
    def close(self):
        pass
    def process_group(self):
        pass
  • January 10, 2024
This works:
import fme
import fmeobjects
    def __init__(self):
        pass
    def close(self):
        pass
        pass
Lol. Apparently you should've been at my FME UC 2023 presentation in Bonn, where I talked about this :-)
nielsgerrits
This works:
import fme
import fmeobjects
    def __init__(self):
        pass
    def close(self):
        pass
        pass
I was :) this was the reason I knew I needed to look for the fmeobject module .
asablomberg
  • January 10, 2024
This works:
import fme
import fmeobjects
    def __init__(self):
        pass
    def close(self):
        pass
        pass
Thank you so much for the very fast response!! :)
