I am reading in an ESRI File GDB, and using several attribute transformers to populate existing fields. Everything is working the way that I want it to (looking at the inspector), however the changes are not being committed to the tables when the translation completes.
Do I need to have a writer in place to commit the attribute changes to the table? Is there something else that I need to add to tell the process it is complete, and the changes can be committed?
I am not looking to create any outputs just update the attributes that I have targeted.
