How to cut roof polygons from dormer which are inside the main roof?
limo
Forum|alt.badge.img+8
We have digitized some roofs with dormers.
Now during the creation process the dormers were digitized into the main roof to avoid gaps. Unfortnatley there were no snapping used.
For example:
imageIs there a way in fme to cut these roof polygons from dormers which are inside the main roof (blue line)?
Best answer by daveatsafe
Hi @limo​,
In FME 2022 and up, you can use an Extruder transformer to extrude the roof polygons into solids. Set the Direction to Vertical and the Distance to the negative of the Z range of the polygon. Use the resulting extrusions to clip the roof polygons with a Clipper.
daveatsafe
Forum|alt.badge.img+19
  • October 19, 2022
Hi @limo​,
limo
  • October 20, 2022
thanks @daveatsafe​ ! This is working for me. The inner roof surfaces are cut off:
