How to use Transformer BRepSolidBoundaryCreator.Beta for composite surface geometries?
  • August 22, 2022
  • 26 views
limo
Forum|alt.badge.img+8
Hi all,
I have roof shapes which I transform to fme_composite_surface (GeometryCoercer). Now I will use BRepSolidBoundaryCreator.Beta to create ground and walls. It works for a single building.
Unfortunatley if I use a bigger area the transformer stopped by saying:
BRepSolidBoundaryCreator.Beta_2_DonutBuilder_<Rejected> (TeeFactory): BRepSolidBoundaryCreator.Beta_2_DonutBuilder_<Rejected>: Termination Message: 'Element BRepSolidBoundaryCreator.Beta_DonutBuilder gibt ein <Rejected>-Feature aus. Um mit der Umsetzung fortzufahren, wenn Features abgewiesen werden, ändern Sie 'Workspace-Parameter' > Umsetzung > 'Behandlung abgewiesener Features' in 'Umsetzung fortsetzen''
What is going on here? Are donut polygons not working?
Inside Transformer BRepSolidBoundaryCreator_Beta error comes from DonutBuilder: INVALID_GEOMETRY_DEGENERATE
How can I avoid this?
evieatsafe
  • September 9, 2022
@Takashi Iijima​ ​ does Pacific Spatial Solutions have any insights on what could be going wrong with this custom transformer?
