Spatial filter not giving the correct result.
  • March 18, 2022
  • 6 replies
  • 368 views
I have a spatial filter that isn't giving me the correct result. I am trying to determine if a feature falls within a polygon. If it does it should pass. If it doesn't it should fail. I know the feature is within the polygon and therefore should be 'passing' but instead it keeps failing. I'm assuming I have something set incorrectly. These are my parameters:
Filter type: Multiple Filters
Pass Criteria: Pass against one filter
Support Mode: Support aggregates
Spatial Predicates to test: Contains candidate, touches candidate, intersects candidate
Use bounding box: no
Curve boundary rule: Default rule
Merge attributes is selected
Accumulation mode: Merge Filter
Conflict resolution: Use candidate
Preserves Feature Order: Per output port
Best answer by markatsafe
@chris28​ There are two coordinate systems:
  • SPHERICAL_MERCATOR for the Filter area
  • CANA83-10TM115-EAP for the Candidate
If I reproject the Filter area (test_against_poly) to CANA83-10TM115-EAP then the SpatialFilter seems to work as expected using the Spatial Predicates to Test: "Filter OGC-Intersects Candidate"
@chris28​ The usual reason SpatialFilter fails to make a match is because the the two input datasets have difference coordinate systems. If your inspecting your data in Data Inspector, switch off background maps.
If this isn't the problem, please feel free to attached a small sample dataset
  • March 18, 2022
They are not in the same coordinate system but before the filter I am using the ESRIReprojector to project the data first. So therefore they should be in the same coordinate system when they are being matched. I've attached a sample of the data though.
gisgis
Forum|alt.badge.img+4
  • March 20, 2022
Hello Chris, in my case it worked! You are using 2 different CS. I reprojected your "input_poly" to "test_against_poly" EPSG: 3400 --> EPSG: 3857 and instead of "SpatialFilter", I use AreaonAreaOverlayer. I hope it helps
123Sorry my FME is in German but I hope its still readable.
  • March 21, 2022
Thank you gisgis. I am doing a reproject but the AreaonAreaOverlayer won't work as I don't want them both output. I just want the filter to check if the input_poly is located inside or touches the test_against_polygon. If it passes then it will move on to the next test.
  • March 22, 2022
  • March 22, 2022
Thanks for your help markatsafe. I did have the reprojector but it wasn't giving me the correct result. I changed it up and now it's working.
