I have a workspace that was just pulling data and joining schema from two feature classes from an enterprise geodatabase. Then, we had a business need to add two new fields to the output feature class. (I cannot add them to the input feature class). Now, when I run the workspace, it overwrites the edits to those two new fields. Does anyone have suggestions on how to set this up in FME so that the two new fields (flagged and flagged description) aren't overwritten? Here is a screenshot of the workspace.
Thanks!
