Multiple pdfs in order sequence in one booklet is possible in FME ?
  • April 5, 2023
  • 62 views
malikusama95
i want to merge multiple pdfs in order sequence and in one booklet
how i can do
please help me FME_q1
virtualcitymatt
Forum|alt.badge.img+47
I'm not sure FME is the right tool for this task. If you need/want to use FME for this I suggest finding a command line tool which can merge pdf files and use the SystemCaller to run the job.
This perhaps could also be done somehow with python in FME.
malikusama95
Thanks for answer ,
can you please share how can i do with python in FME
virtualcitymatt
Thanks for answer ,
Here's something I found online which should be helpful: https://stackoverflow.com/questions/3444645/merge-pdf-files
In FME you can use a PATH reader to read the file names of the PDF files as features in FME. You can then feed them into the PythonCaller with your code.
