Not sure if I understand what you are after, but I think you have trouble with the order of the records and the line not being build chronologically? I think you first need to reformat the date field (RecordedAt) to fme datetime using the DateTimeConverter, then you will be able to use a Sorter to get the order right and then build the line.
For creating a line from points you can use a LineBuilder or a VertexCreator.
Hello Nielsgerrits
Thank you very much for your answer. If you are available, could you help me if I send you my file?
Hello Nielsgerrits
thank you very much it helped a lot with some minor fixes I got a very good result
Hello Nielsgerrits
Happy I could help :)
Upon further inspection I found the PreviousRecording class with the tracks. You could split the tracks on segment length (Chopper 2 vertices, LenghtCalclulator, Tester, LineCombiner) or elapsed time between points (AttributeCreator with Adjacent Feature Attributes enabled, calculate DateTimeDiff (@DateTimeDiff(@Value(RecordedAt),@Value(feature[-1].RecordedAt),seconds)) between points, create a new group if elapse time is greater then 10 seconds.
