How to implement a range value expression as key in feature merger
  • July 19, 2023
  • 23 views
keller
Forum|alt.badge.img+7
This might be an easy one but i could not find a way around it, I have two files File A (lines with geometry) and File B CSV file(lines without geometry). Both files have ID,START,END columns as shown below. So i was wondering how can i merge them on ID as the first key and also specify the range of the start value as the second key, (any other approach is welcomed)imageso what i expect is the first two values of FileB be given geometry from the first value of file A, and the third value of FileB be given geometry from the second value from FileA.
Thanks ,
Keller.
Forum|alt.badge.img+46
  • July 19, 2023
You should be able to use the InlineQuerier for this, something like
SELECT B.*, A.A_ID FROM
FileA A,
FileB B
WHERE A.ID = B.ID
AND B.START >= A.START
AND B.END <= A.END
