the ultimate goal is to have two outputs, the selected line or lines based on an attribute value and the neighbouring/adjacent lines within a 100m buffer. So am wondering what would be the best way to loop through the million records selecting features by attribute value then run the process and then the next batch so on ...? any help in decoding this will be highly appreciated.
