Filter data based on multiple columns
  • November 17, 2021
  • 124 views
As an example, in Excel you would use the filter function and select specific values from the drop down menu across multiple columns.
How in FME do you filter rows of data based on attributes held in multiple columns?
I've looked at the two SQL translators; SQLCreator and SQLExcuter but both need connecting directly to a database. In my case I need to use the transformer within my workflow.
Thanks.
Best answer by drc43
You can use a Tester transformer with an AND or OR (or other) logic on multiple rows in the transformer to 'test' multiple fields.
http://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/tester.htm
drc43
Forum|alt.badge.img+11
  • November 17, 2021
geomancer
Forum|alt.badge.img+47
  • November 18, 2021
Or if you absolutely want to use SQL, take a look at the InlineQuerier.
  • November 19, 2021
Thank you that's perfect.
  • November 19, 2021
I'll keep this in mind for the future!
