Hi, I have two line features and would like to update an attribute on feature "A" from feature "B" if they are intersected to each other, is there any specific transformer or work flow fo this task?
  • August 31, 2023
  • 43 views
Best answer by DanAtSafe
Hi @arashjazini​ Every value for _related_candidates is 0, which means that none of the Requestors pass the spatial predicate. Either change that or else you'll need to change the geometry with a LineExtender, Snapper or AnchoredSnapper.
DanAtSafe
Forum|alt.badge.img+22
  • September 1, 2023
Hi @arashjazini​ You can use a SpatialRelator with the "Requestor OGC-Touches Supplier" Spatial Predicate. Be sure to enable Merge Attributes and use the default "Merge Supplier" Accumulation Mode.
  • September 1, 2023
Hi Dan, Thank you for you answer!
The transformer output missing some values , any ideas?
DanAtSafe
  • September 1, 2023
  • September 11, 2023
Thanks for the help Dan!
