I need to generate a list of polygons from Dataset Y that overlap with Dataset Z and the percentages each polygon overlaps the polygons in the other dataset.
I’ve currently used a spatial relator > list concatenator to find overlapping polygons but it then requires a lot of additional work in excel to get it into a usable table so I am not getting results in the format I need.
The data essentially looks like the follow example and I need something similar to the Ideal Resulting Dataset or in a format that is easy to follow or easy to turn into that dataset.
Example
Dataset Y
1
2
3
4
Dataset Z
A
B
C
D
Spatially Datasets Y and Z:
Ideal Resulting Dataset:
