Multiple values of elements XML to separate attributes
  • August 25, 2020
  • 136 views
pzwaag_wf
I have been puzzling for a while how to process data available on the Dutch portal www.pdok.nl
After downloading a gml-file (type Dutch TOP 10 GML), I would like to extract the information stored in elements and convert this information into attributes.
Therefore I use the XMLQueryExtractor. This does the job, information is temporarily stored in lists but this is a very timeconsuming process. Examples of elements with multiple values from the featuretype ‘Wegdeel’ are naam, typeWeg ,hoofdverkeersgebruik and fysiekVoorkomen.  Is there a more efficient method?
I have attatched an example workspace…
Many thanks in advance.
(v 2019.2.2)
Best answer by debbiatsafe
Hi @pzwaag_wf​
I don't believe it's necessary to XMLXQueryExtractor to store the attribute values in a list and then parse out the values again.
The attribute values are stored in lists, which are not automatically exposed on features. Simply use the AttributeExposer to expose the attributes. I have attached an example of this workflow. I hope this helps.
debbiatsafe
Forum|alt.badge.img+21
  • August 26, 2020
Hi @pzwaag_wf​
pzwaag_wf
  • August 27, 2020
Hi @pzwaag_wf​
​Dear Debbi,
You are abolutely right, this saved many, many hours.....
Thank you very much.
Kind regards,
Pim van der Zwaag.
