Comparing two fields based on a string match
  • July 31, 2016
  • 321 views
Hello All, I have two tables like below. I want to know the difference (add, delete, unchanged) of the TractID field between these two tables. For instance, i want to have a output showing
unchanged: 1001, 1003
added: 1002, 1004, 1005
deleted: 1009
I didn't see the ChangeDetector transformer is able to compare two fields based on a string match. How to achieve this? I appreciate your help!
Table 1 (old):
IDTractID101001111003121009
Table 2 (new):
UniqueIDTractID1100121002,1003,100431005,1006
Best answer by takashi
Hi @fmenewbie, the ChangeDetector can compare entire string match, but cannot detect partial matching. Split TractID of the table 2 into individual id values using the AttributeSplitter and explode the records on the resulting list using the ListExploder. You can then compare individual TractID using the ChangeDetector.
  • July 31, 2016
