How to install packages with Pip to the python3 installation in FME Workbench on MacOS
  • July 31, 2020
  • 109 views
Hello, I am trying to install a few python modules to the python 3 installation included with FME workbench 2020.1 on MacOS Catalina 10.15.6. using pip
is there a way to do this? furthermore, is it possible to use a virtual environment?
danilo_fme
Forum|alt.badge.img+52
  • August 3, 2020
Hi @awoestreicher​
There is a interesting documentation about Installing Python Packages to FME Desktop.
You can check the option for type of system pip to install a Python package.
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_DataInspector/Workbench/Installing-Python-Packages.htm
Thanks,
Danilo
