Please can you tell me how i do this?
- Home
- Forums
- FME Form
- Transformers
- Within the AttributeManager transformer i currently apply the following to an attribute: @FullTitleCase(@Value(fme_feature_type)) However, i would like this to exclude the following words, which should be lower case only: And Of Or
- July 1, 2023
- 9 replies
- 10 views
- Supporter
- 222 replies
- July 1, 2023
I don't think you can prevent it capitalising words, so you'll have to adjust it after. It's not a perfect solution, but you can undo the capitalisation of those worlds with a StringPairReplacer with:
\\ And\\ \\ and\\ \\ Of\\ \\ of\\ \\ Or\\ \\ or\\
the \\ escapes spaces, so it's replacing <space>And<space> with <space>and<space>. Normally this wouldn't work because of commas and other punctuation around words, but you might be able to get away with it.
- Author
- 8 replies
- July 3, 2023
\ And\ \ and\ \ Of\ \ of\ \ Or\ \ or\
the \ escapes spaces, so it's replacing <space>And<space> with <space>and<space>. Normally this wouldn't work because of commas and other punctuation around words, but you might be able to get away with it.
I tried adding this but it generated 26 errors.
It appears to take exception to every attribute in the dataset, rather than just focussing on the fme_feature_type value specified in the StringPairReplacer. These are the 26 errors:
Feature Type: `StringPairReplacer_OUTPUT'
Attribute(string: UTF-8) : `DIVISION' has value `2'
Attribute(string: UTF-8) : `DIVISION_alias' has value `Division'
Attribute(32 bit integer): `REACH' has value `2'
Attribute(string: UTF-8) : `REACH_alias' has value `Reach'
Attribute(string: UTF-8) : `RIVER' has value `Rhymney'
Attribute(string: UTF-8) : `SHAPEFILE_TYPE' has value `shapefile_polygon'
Attribute(64 bit real) : `SHAPE_AREA' has value `5813.21933263'
Attribute(64 bit real) : `SHAPE_LENG' has value `384.913033824'
Attribute(string: UTF-8) : `fme_feature_type' has value `Rhymney_Backwater_Wetland_And_Wet_Woodland_Creation
Attribute(string: UTF-8) : `fme_geometry' has value `fme_polygon'
Attribute(string: UTF-8) : `fme_type' has value `fme_area'
Attribute(string: UTF-8) : `geodb_feature_class_alias' has value `RHYMNEY_BACKWATER_WETLAND_AND_WET_WOODLAND_CREATION'
Coordinate System: `_OSGB-GPS-2015-OSTN15_0'
Geometry Type: IFMEPolygon
Name(UTF-8): `shapefile'
Boundary:
Geometry Type: IFMELine
Number of Coordinates: 12 -- Coordinate Dimension: 2
(315370.5318999998,196649.5253999997)(315380.60500000045,196548.55819999985)(315404.86209999956,196505.69600000046)(315400.3875000002,196489.21050000004)(315386.25710000005,196480.02580000088)
(315366.51999999955,196485.49000000022)(315344.57239999995,196527.12710000016)(315340.0848000003,196592.63819999993)(315340.5075000003,196600.52889999934)(315341.84609999973,196609.82870000042)
(315346.15110000037,196622.3509999998)(315370.5318999998,196649.5253999997)
StringPairReplacer (TeeFactory): StringPairReplacer: @Tcl2 -- failed to evaluate expression `StringPairReplacer_7ff7c7b7_b72b_4bdd_b766_b3a9b991dd123_replace' -- char map list unbalanced
Any idea why this would be happening?
- 8317 replies
- July 3, 2023
Try the following code in a PythonCaller:
import fme
import fmeobjects
class TitleCaseWithExceptions(object):
def __init__(self):
pass
def input(self, feature):
title = feature.getAttribute('my_text') or ''
exceptions = 'and of or'.split(' ')
title_case = ' '.join(x.title() if nm==0 or not x in exceptions else x for nm,x in enumerate(title.split(' ')))
feature.setAttribute('my_text', title_case)
self.pyoutput(feature)
def close(self):
pass
You can modify the exceptions on line 11. The function will assume the title is held in the attribute my_text, but you can easily change this on lines 10 and 15.
Sample input: a man and his dog out of this world or space
Sample output: A Man and His Dog Out of This World or Space
Based on https://stackoverflow.com/a/34779072
- Author
- 8 replies
- July 3, 2023
import fme
import fmeobjects
def __init__(self):
pass
def close(self):
pass
Hello David_r
Python Compatibility: ESRI ArcGIS Python 3.7
This resulted in ArcObjects error -2147220654
An error occurred while attempting to create the feature class 'RHYMNEY_BACKWATER_WETLAND_AND_WET_WOODLAND_CREATION
'. The error number from ArcObjects is: '-2147220654'. The error message from ArcObjects is: {The table name is invalid. [RHYMNEY_BACKWATER_WETLAND_AND_WET_WOODLAND_CREATION
GEODATABASE_FILE writer: An error has occurred. Check the logfile above for details
PythonFactory output feature was rejected downstream. Check the logfile above for details
Error encountered while calling method `input'
PythonCaller (PythonFactory): PythonFactory failed to process feature
Here is an excerpt from the log file:
2023-07-03 11:14:21| 0.9| 0.0|INFORM|Writer `GEODATABASE_FILE_2' of type `GEODATABASE_FILE' using group definition keyword `GEODATABASE_FILE_2_DEF'
2023-07-03 11:14:21| 0.9| 0.0|INFORM|An ArcGIS license is already checked out. The product checked out is 'Standard'
2023-07-03 11:14:21| 0.9| 0.0|INFORM|Installed ArcGIS version is '2.9.6'
2023-07-03 11:14:22| 0.9| 0.0|INFORM|Deleted the existing File Geodatabase 'Z:\Processing\Knowledge Data & Information Management\1 - Geospatial\A Olly\Data Loading\Rhodri Powell\FME_POLYGON_OUTPUT.gdb'
2023-07-03 11:14:33| 1.2| 0.3|INFORM|Created and connected to the ArcGIS 10.0 File Geodatabase at 'Z:\Processing\Knowledge Data & Information Management\1 - Geospatial\A Olly\Data Loading\Rhodri Powell\FME_POLYGON_OUTPUT.gdb'
2023-07-03 11:14:33| 1.2| 0.0|INFORM|Fast deletes enabled
2023-07-03 11:14:33| 1.2| 0.0|INFORM|The 'HAS_Z_VALUES' keyword is set to 'AUTO_DETECT'. With the exception of MultiPatch feature classes, the dimensionality of new feature classes will be based on the first feature written to the feature class. (Features with no geometry are considered 2D)
2023-07-03 11:14:33| 1.2| 0.0|INFORM|A default z-value of '0' will be used for all 3D features where z-values are not provided
2023-07-03 11:14:33| 1.2| 0.0|INFORM|Esri Geodatabase Writer: Not simplifying geometries being written
2023-07-03 11:14:33| 1.2| 0.0|INFORM|Transactions are being used by the Esri Geodatabase Writer
2023-07-03 11:14:37| 1.6| 0.4|INFORM|Esri Geodatabase Writer: Creating feature type `RHYMNEY_BACKWATER_WETLAND_AND_WET_WOODLAND_CREATION
2023-07-03 11:14:37| 1.6| 0.0|ERROR |An error occurred while attempting to create the feature class 'RHYMNEY_BACKWATER_WETLAND_AND_WET_WOODLAND_CREATION
2023-07-03 11:14:37| 1.6| 0.0|ERROR |GEODATABASE_FILE writer: An error has occurred. Check the logfile above for details
2023-07-03 11:14:37| 1.6| 0.0|FATAL |PythonFactory output feature was rejected downstream. Check the logfile above for details
2023-07-03 11:14:37| 1.6| 0.0|ERROR |An error has occurred. Check the logfile above for details
2023-07-03 11:14:37| 1.6| 0.0|ERROR |Error encountered while calling method `input'
2023-07-03 11:14:37| 1.6| 0.0|FATAL |PythonCaller (PythonFactory): PythonFactory failed to process feature
2023-07-03 11:14:37| 1.6| 0.0|STATS |GeodatabaseRelationshipFeaturesPipeline::GeodatabaseRelationshipFeatures (SortFactory): Finished sorting a total of 0 features.
2023-07-03 11:14:37| 1.6| 0.0|INFORM|Transaction #1 rolled back. Rerun translation specifying transaction #0 for the keyword 'TRANSACTION'
2023-07-03 11:14:37| 1.6| 0.0|INFORM|Closing the Esri Geodatabase writer
2023-07-03 11:14:37| 1.6| 0.0|INFORM|=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
2023-07-03 11:14:37| 1.6| 0.0|INFORM|Feature output statistics for `GEODATABASE_FILE' writer using keyword `GEODATABASE_FILE_2':
2023-07-03 11:14:37| 1.6| 0.0|STATS |=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
2023-07-03 11:14:37| 1.6| 0.0|STATS | Features Written
2023-07-03 11:14:37| 1.6| 0.0|STATS |RHYMNEY_BACKWATER_WETLAND_AND_WET_WOODLAND_CREATION
2023-07-03 11:14:37| 1.6| 0.0|STATS | 1
2023-07-03 11:14:37| 1.6| 0.0|STATS |==============================================================================
2023-07-03 11:14:37| 1.6| 0.0|STATS |Total Features Written 1
2023-07-03 11:14:37| 1.6| 0.0|INFORM|Path Reader: Closing the PATH Reader
2023-07-03 11:14:37| 1.6| 0.0|INFORM|Translation FAILED with 6 error(s) and 0 warning(s) (1 feature(s) output)
2023-07-03 11:14:37| 1.6| 0.0|INFORM|FME Session Duration: 19.1 seconds. (CPU: 0.6s user, 1.0s system)
2023-07-03 11:14:37| 1.6| 0.0|INFORM|END - ProcessID: 1588, peak process memory usage: 219860 kB, current process memory usage: 213608 kB
- 8317 replies
- July 3, 2023
Hello David_r
I kind of looks like you have a trailing linefeed at the end of the feature class name RHYMNEY_BACKWATER_WETLAND_AND_WET_WOODLAND_CREATION
- Author
- 8 replies
- July 3, 2023
Hello David_r
Presumably this has been introduced in the python code because this is not present in the source data:
So how would i remove this?
- 8317 replies
- July 3, 2023
Hello David_r
I'm struggling to see how the Python code above could introduce a newline on its own. You can take care of it either by replacing line 15 with this:
feature.setAttribute('my_text', title_case.strip())
Or by using an AttributeTrimmer before the writer.
- Author
- 8 replies
- July 3, 2023
Hello David_r
Thank you for trying David but unfortunately this still results in the same errors
- Evangelist
- 857 replies
- July 4, 2023
You have underscores in fme_feature_type, so there is no need for all those 'escaped' spaces.
You can simply replace _And_ with _and_, etcetera.
Related Topics
Please support mmhmm and alternate cameras in RingCentral Meetingsicon
Video, Meetings, Webinar, Rooms, & RingCentral EventsRingCentral not recognizing cameraicon
Video, Meetings, Webinar, Rooms, & RingCentral EventsVideo Settings RingCentral Meetings Issueicon
Video, Meetings, Webinar, Rooms, & RingCentral EventsCan RingCentral Meetings support 2 camera's like Zoom does?icon
Video, Meetings, Webinar, Rooms, & RingCentral EventsZoom and RingCentral Security agreementicon
Helpful Members This Week
- liamfez
22 votes
- redgeographics
20 votes
- crutledge
18 votes
- j.botterill
14 votes
- nielsgerrits
13 votes
- philippeb
12 votes
- s.jager
11 votes
- kailinatsafe
10 votes
- takashi
10 votes
- geomancer
9 votes
Recently Solved Questions
Can't merge wallls together in 3d buildings
2 RepliesPoint clouds - find the lowest height in clusters
6 RepliesPointOnAreaOverlayer not producing expected results
2 RepliesUnderstanding parallel processing in FME Form
5 RepliesIs there a way to change generated FME engine result zipped file name?
Community Stats
- 30,971
- Posts
- 117,398
- Replies
- 38,758
- Members
Latest FME
Scanning file for viruses.
Sorry, we're still checking this file's contents to make sure it's safe to download. Please try again in a few minutes.
OKThis file cannot be downloaded
Sorry, our virus scanner detected that this file isn't safe to download.
OKCookie policy
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
