What causes Python Exception <KeyError>: 'DYNAMIC'
  • October 14, 2020
  • 79 views
joukje
I have a workbench that uploads features from an AutoCAD drawing to ArcGIS Online. FME is happy to write the first 20000 features (AGOL Feature Service Writer), but then aborts with "Python Exception <KeyError>: 'DYNAMIC'".
Any clues to what can be the cause?
Note: until last week the workbench worked without any errors.
chrisatsafe
  • October 15, 2020
Hi @joukje​
Thanks for reporting this issue.
Since this same workspace worked last week, did you recently upgrade FME builds/versions? If so, what version were you previously running and what version are you currently running? Our team recently released a fix to a similar issue in both of the beta builds b20751+ win64 and b21183+. If you could try out the workspace in either the latest 2020.2 or 2021.0 beta and let me know if that resolves the issue that would be great!
