Hi experts, I'd like to extract text that is within the brackets or trim characters left of the bracket. The length of characters is varied. e.g C213 (Sturt Hwy) -> Sturt Hwy apprecialte your help
  • September 23, 2020
  • 135 views
Best answer by redgeographics
Assuming it's always a single occurance of a text between brackets you can use a StringReplacer to replace the regex ^.*\\(|\\).*$ with an empty string
Screenshot 2020-09-23 at 09.28.26
Forum|alt.badge.img+62
Thanks so much! worked well..............
