Best Answer
CITYgml:'CityGML Reader: The number of UV Texture coordinates did not match the coordinates of the geometry
  • May 7, 2013
  • 47 views
Hello everybody, I'm a noncertiefied FME-Greenhorn.
I will try to transfer CITYgml- Data into Microstation V8 and both, the internal MS- FME- Port and FME as Standalone, will give the Errorcode: 'CityGML Reader: The number of UV Texture coordinates did not match the coordinates of the geometry. Received '0' texture coordinates but the geometry has '4' points.'. There is some Geometry, which apperas in Microstation as single Lines (no shapes!) - but the Textures are not transfered (or not displayed because of the Elementtype?).
The same Error will apear by transfer to dxf, kml, LANDxml or SetchUp- Format - without the Geometrydata as Result. So maybe the Reader will not accept the Data?
On the other hand, i'm easily able to watch the Data inside Terrainview of Terratec!
Any Ideas?
Best Regards
tom
Best answer by fmelizard
Some more information can be useful, are you using FME 2013?
How are you setting the citygml reader (schema, ADE)?
Have checked the include texture option on?
Itay
fmelizard
Forum|alt.badge.img+21
  • May 7, 2013
Itay
