Hello, I am creating a list in a pythonCaller which contains lists inside. Similar to this example: mylist=[[4, 5, 6], [1, 2, 3], [9,8,7], [10,14,13], [5,9,10]]. How can I expose this list to pass it to the next transformer ? The usual way of feature.setAttribute('mylist{}', mylist) is not working. My script is working fine when I am running it outside of FME. I am getting the following error in FME:
"Python Exception <TypeError>: Could not convert attribute value to a supported attribute type.
Error encountered while calling function `processFeature'
PythonCaller_3 (PythonFactory): PythonFactory failed to process feature"
