GeoTiff palette issue - strange numbers of palette displaying in QGIS
  • December 15, 2022
  • 34 views
I have simple script with adding color palette to raster ASC after cell value replacer .
In ouput GeoTIFF i received too many palette colors represented with black color. |
obraz_2022-12-15_094950356In attachment i send script.
It's possible to have only 3 selected colors without black numbers?
Best answer by virtualcitymatt
So to do this you need to coerce the output raster to UInt8 and then set the number of "Bits per cell" to 2 (in the advanced FeatureType parameters). This will give you a maximum of four values. (0-4)
virtualcitymatt
Forum|alt.badge.img+47
  • December 15, 2022
Great, it works correctly,
thank you so much
