XMLTemplater - How to use conditional value in the root template?
  • June 19, 2022
  • 41 views
ashish_man
The XML Templater fails when I give a conditional value in the root template. XMLTemplater_3: Invalid Test Expression: TEST<at>Value<openparen>template_root<closeparen>=1
I have attached a simple workspace, any ideas why the conditional check fails?
Thanks
