With an http caller I execute get requests. This is done in a loop to enable pagination. Sometimes the server that receives and handles the request has trouble handling it and returns an error message. Is it possible to put a decelerator after the rejected port of the httpcaller and then redirect it to the inport of the loop so that the last get request is executed again and the workspace continues?
