How to write globalids from AGO without the curly braces?
  • December 11, 2023
  • 93 views
masonb12
Forum|alt.badge.img+14
Hi, I can read an arcgis online feature service using fme AGO reader. The globalids all have a curly brackets in the inspector. Is there a way to write the feature to a new table without the curly brackets. Curly brackets are messing things up when using globalids in url links. thanks
Best answer by hkingsbury
Before you write the data out, you can use a string replacer and regex to replace the curly braces with nothing.
Set the mode of the string replacer to  "Replace Regular Expression" and the "Text To Replace" as
Leave the "Replacement Text" blank.
The above regex 'translates' to find "{" or "}"
hkingsbury
Forum|alt.badge.img+67
  • December 12, 2023
masonb12
  • December 12, 2023
Thanks! that works very well!
masonb12
  • December 12, 2023
Also, is it possible to also add .jpg to the end of each globalid
thanks
hkingsbury
  • December 12, 2023
thanks
you can appended it on in an attribute creator
