Help with the StringReplacer transformer!
  • August 28, 2020
  • 36 views
cshir065
Hi there,
I have a spreadsheet where I need to replace a string of text. I have attached the spreadsheet with the original text and what I would like to replace it with. I'm having trouble coming up with the correct syntax in the 'Text To Replace' in the 'Parameters' dialog box.
I can get the first string to replace but not the second. Please see attached screenshots.
Thank you and have a nice weekend :)
Best answer by bwn
I would try instead StringPairReplacer as it looks like the workflow is just replacing a paired fixed list of input substrings with a fixed list of replacement substrings.
bwn
Forum|alt.badge.img+26
  • August 29, 2020
cshir065
  • August 29, 2020
Thanks, @bwn​. I tried StringPairReplacer and it did exactly what I wanted.
