Problem setting up a WMS service in the Data Inspector
  • September 14, 2021
  • 86 views
eric_armitage
Forum|alt.badge.img+10
UdklipI have a problem setting up a WMS background maps in FME from this site. https://kortforsyningen.dk/indhold/webservice-liste. I have tried a few different services but can't get any of them to work. AGOL maps work ok. The layer list is read ok so I assume the token is valid but the background map doesn't show when the workspace is run. Anyone got any suggestions how to fix this?
Forum|alt.badge.img+62
Did you specify the coordinate system in the previous dialog? Can you try reading this WMS inside an FME workspace, by using a reader or FeatureReader? This should give you some more error messages in the log which could help in trying to figure out what's going on.
Are you able to view this WMS in another application?
