I am reading the polygon and Lines dataset in FME. I need to select lines that are intersecting a polygon and populate the polygon name in Lines. I have used tester after feature to filter one polygon and select intersecting lines using a spatial filter. Is there a way to loop through a polygon feature and select one polygon at a time in FME, Instead of entering the Polygon name in a tester every time.
Rather than populating the Highlands-CCD attributes, it populates the name of the bigger polygon from which the small polygon overlaps.
