I currently have 2 datasets - one is a set of records with a date attribute. The other is a schedule dataset with 2 attributes indicating the start and finish dates.
I am trying to identify how I can query whether a record in dataset one is within the range of the start and end dates of dataset two, and then subsequently count the number of times each record appears in the range of dates
The end result ideally is something similar to the statistics calculator where I would see each record with an extra attribute with a numerical value indicative of how many times that date has occurred in the range of the schedule dataset.
