Hello all, I need a help about how to iterate an entire workflow in such a way,so that once I change the inputs,it will provide me with the specific output
  • September 3, 2019
  • 10 views
oscard
Forum|alt.badge.img+22
  • September 3, 2019
Not sure if I understand what your goal is, but it sounds that you need to define some user parameters. So, when the users run the process, they are asked for the value of the inputs you need to change.
