Hi.
I'm working on a project where I need to find points within a distance of each other and assign a value to each neighbor. I'm using a neighborfinder with "candidates only", blank number of neighbors to find, given max distance and the ID of each point is added to a list. The points are close together, so the same points will be found for each candidate.
What I'd like is to add a value to each of the closest candidates based on a attribute value on the feature. Do you have any a ideas on how to solve this?
Torbjørn
When you're setting up the NeighborFinder you can use Attribute Accumulation, either the Merge Attributes or the Generate List option, to add attributes of the found neighbors.
