Is it possible to disable one published parmaters based on the value of some other pubished parameter.
  • February 4, 2021
  • 7 replies
  • 46 views
stipica.pavicic
Participant
For example:
Parameter 1:
Calculate area: yes/no
Parameter 2:
Units: m2/ km2,....
I would like to disable parameter 2 if the value of the parameter 1 is set to "no".
At the same time I would like to have Parameter 2 as an mandatory parameter if the value of the Parameter 1 is "yes"
Thank you!
There is nesting (tree) in the published parameter 'Choice' that you can use a Tester or TestFilter on to build your logic. Basically, you create a case for each possible combination in a delimited list and then use the one you want.
http://docs.safe.com/fme/2020.2/html/FME_Desktop_Documentation/FME_Workbench/!Transformer_Parameters/adding_a_parameter.htm?Highlight=use tree
The other way is to use a series of testers to meet conditions. I use either one depending on the complexity of the data.
  • February 4, 2021
Alternatively, have a look at FME 2021 (currently in beta), where there is a lot of new functionality in this regard. Available here: https://www.safe.com/support/downloads/#beta
stipica.pavicic
Participant
Thanks for yur answer but I'm not sure if I understood correctly.
Are you basicaly proposing to have everything inside one parameter with the provided choice of all possible combinations? Can you make a sample workspace that will help to understand better?
Anyway, I would like to keep all parameters and to disable one (or more) in the case when the parameter/s are not relvant in relation to values selected on other parameter/s.
One simple example is provided and explained earlier in the post but it can be much more complex case with many parameters and complex depandancise between them.
I just want to make things more user freindly when I create custom transformer or when I make a workspace for customers.
stipica.pavicic
Participant
Thanks
  • February 4, 2021
as @david_r​ mentions. FME 2021 will include a new parameter builder tool that will allow this sort of inheritance. Watch for the 2021 What's Great webinars which should be on the schedule fairly soon
  • February 4, 2021
Thanks
Webinar date has been confirmed 9th March 2021
stipica.pavicic
Participant
Thanks!
I'm looking forward to seeing the webinar.
