Hello ,
i have 2 dataset with different geometry
points has the same id (points id at dataset 1 is the same points id at dataset 2 (same color as picture) but each point has different geometry and lines also has different geometry.
probably , there are few points Id at the middle of network at dataset 1 are not the same point Id at dataset 2 .
Lines in each dataset has different id ,
but they connect with same id point in different dataset but with different geometry .
i would like to compare between two dataset and find which line id from dataset 1 equal line id from dataset 2 .
my target to get specific attribute from lines at dataset 1 to provide for each lines equally at dataset 2 .
FME 2021
