merge 2 attributes from a list on a new attribute list
  • October 26, 2023
  • 8 replies
  • 106 views
alc33
Forum|alt.badge.img+14
Hi !
I have a list named "coord" that contain 2 attributes "x" and "y". I would like to create an other attribute that concatate "x" and "y". For example :
line number 1 (one geometry) :
coord{0}.x = 1.25
coord{0}.y = 1.25
coord{1}.x = 2.25
coord{1}.y = 2.25
Résult :
coord{0}.x = 1.25
coord{0}.y = 1.25
coord{0}.all = 1.25;1.25
coord{1}.x = 2.25
coord{1}.y = 2.25
coord{1}.all = 2.25;2.25
Thanks for your help !
panda
Forum|alt.badge.img+20
  • October 26, 2023
I was able to do it by using ListExploder and use Attribute Creator to create new attribute call combine and then put it back together using ListBuilder with Group Processing using ObjectID (or any unique number to that feature)
I compare the line after it put back together to make sure that element index actually go back to the correct place and it seem like it does (But definitely randomly check it in your case just to make sure)
Merge2att
alc33
  • October 27, 2023
Hi! Thanks for your answer. It work very well. Do you think it's possible to add a new attribute list using Python, to avoid geometry manipulation?
  • October 27, 2023
Hi @alc33​ ,
PythonCaller with this script might help you.
class FeatureProcessor(object):
    def __init__(self):
        pass
    def input(self, feature: fmeobjects.FMEFeature):
        xs = feature.getAttribute('coord{}.x')
        ys = feature.getAttribute('coord{}.y')
        feature.setAttribute('coord{}.all', ['%s;%s' % (x, y) for x, y in zip(xs, ys)])
        self.pyoutput(feature)
    def has_support_for(self, support_type: int):
        return support_type == fmeobjects.FME_SUPPORT_FEATURE_TABLE_SHIM
    def close(self):
        pass
    def process_group(self):
        pass
alc33
  • October 27, 2023
Hi @alc33​ ,
    def __init__(self):
        pass
    def close(self):
        pass
        pass
@Takashi Iijima​ thanks for your answer !
I'm sorry but I have a termination message and I don't understand why?
I'm using FME 2020.2 and python 3.7+
Thank you.
  • October 27, 2023
Hi @alc33​ ,
    def __init__(self):
        pass
    def close(self):
        pass
        pass
I think the script should work in FME 2020 too.
Most likely you have not created xs and ys (lists of x values and y values) from "coord{}.x" and "coord{}.y".
Check if these two lines are correct.
alc33
  • October 30, 2023
Hi @alc33​ ,
    def __init__(self):
        pass
    def close(self):
        pass
        pass
You are right, the name of the list was different. It work very well! Thank you !
alc33
  • October 30, 2023
thank you very much @panda​ @Takashi Iijima​ !
alc33
  • October 31, 2023
Just a precision for the person that aren't used  to use pythoncaller (like me :) ). Before the code above you have to write :
import fme
import fmeobjects
This 2 lines are in the transformer at his opening.
And then, to see the new attribute in the others transformers, you have to use AttribueExposer.
