I get this error "Workspace generation failed. Parameter file was /private/var/folders/tr/rfmmyq590j17jq9ndl8my5lh0000gn/T/FME_1635634267372_8830." Can anyone help?
  • October 30, 2021
  • 18 replies
  • 578 views
joe_p
Forum|alt.badge.img+3
Hi everyone,
Every time I load a reader into Workbench I get an error similar to this
Not sure what the issue is any help would be very much appreciated.
Best answer by andreaatsafe
Hi all,
I'm pleased to let you know that FME 2021.2 is now released and officially supports macOS Monterey.
You can find the latest release here: safe.com/downloads
-Andrea
virtualcitymatt
Forum|alt.badge.img+47
Things I would try:
  1. Restart the Computer
  2. Reinstall FME
If it happens with all all new workspaces and all formats then there is probably some issue with the install? it could also be related to permissions? perhaps FME doesn't have read/write access to a temp location?
joe_p
  • November 1, 2021
Thanks for your help @virtualcitymatt​ ,
I've tried 1 and 2, but haven't looked into the permissions on Temp location so will give that a go.
After some testing this weekend, I suspect it's because I'm running the latest Mac OS Monterey as I was able to cause the same behaviour on another Mac by updating it. I've put a support ticket in about that as it has the same behaviour on 2020, 2021, 2021.1 and the 2022 beta, I'll keep this thread updated with what I find out incase its of use to someone else!
Cheers
Joe
joe_p
  • November 1, 2021
I just changed the temp location to somewhere I definitely had permission to write to and still same error:
Error running translation.
Workspace generation failed. Parameter file was /Users/joe/Fme_temp/FME_1635763126167_5529.
cnieman
  • November 1, 2021
My coworker and I have the same problem after update to Monterey. Reinstalled FME and reboot did nothing. As far as I can tell, my user still has permissions to write to the temp location.
virtualcitymatt
ooh, seem like this should be a support case then - best contact support directly on this one. https://community.safe.com/s/submit-case/
What FME version are you running?
virtualcitymatt
After some googling I found this gitlub issue which is only a few days old: https://github.com/gperftools/gperftools/issues/1312
It seems like Safe are potentially aware of this, but likely do not have a solution yet.
At the moment you might need to roll back to a previous version of the OS :-/
cnieman
  • November 1, 2021
Oh great... It's not so much of a problem for me as I have a Linux box I can use, but coworker is Mac only.
I was going to make a ticket but OP said they did.
joe_p
  • November 1, 2021
Thanks for checking @virtualcitymatt​ unfortunately I got the new MacBook so can't go back, DOH! So hopefully they can fix soon
I'll keep you updated @cnieman​ with anything I hear
virtualcitymatt
Lets ping someone from safe support - while we're at it :D
 @nampreetatsafe​
andreaatsafe
Forum|alt.badge.img+15
Hi all,
FME 2021.1 and earlier are not currently supported on macOS Monterey.
We are currently working on resolving the issue (internal tracking number: FMEENGINE-71121) and are aiming for the next official release of FME 2021.2 to support macOS Monterey.
- Andrea
cnieman
  • November 1, 2021
Hi Andrea, would it be possible for a note to be added to the download page? There is no indication I can see to inform users that FME currently doesn't work with Monterey.
andreaatsafe
Hi @cnieman​ ,
Our Technical Specifications page outlines the supported OS for the current release of FME 2021.1.
andreaatsafe
  • November 2, 2021
Hi all,
-Andrea
joe_p
  • November 2, 2021
Woohoo! Thanks @andreaatsafe​ and team
  • November 9, 2021
I am having the same issue after recently upgrading to Monterey. I have upgraded to FME 2021.2 but the same problem occurs - but maybe not as frequently. the last instance was when working through the FME Essentials tutorial
  • November 9, 2021
Follow on to my previous comment. I now realise that I had several different versions of FME installed. FME 2021.2 seems to working so far
andreaatsafe
Hi @byroncinnz​ ,
Can you confirm the following:
  1. The type of license you are using - fixed or floating?
  2. What type of Mac - intel based or M1 based? (confirmed with a screenshot preferably)
Please also provide the steps and a screenshot of what you are seeing. If you can provide the crash log report as well (if possible), that would be great. Feel free to submit this via a support ticket here: https://community.safe.com/s/submit-case
-Andrea
  • November 9, 2021
Hi @byroncinnz​ ,
-Andrea
I am on a fixed license. But I think it may be a non-issue. I just realised that I had multiple versions on my MBP and was not actually launching FME 2021.2 when this error appeared.
