Is there a transformer that will convert a multilinestring to a linestring object?
  • March 25, 2023
  • 395 views
thomastupuivao
Forum|alt.badge.img+7
Is there a transformer that will convert a multilinestring to a linestring object? I'm trying to load road centrelines in an oracle spatial database, but the road centreline table in oracle uses GTYPE 2002 (line). Multilinestring is 2006, so I can't apply a spatial index. Any suggestions please?
Best answer by david_r
Try using a Deaggregator and, if necessary, followed by a GeometryRefiner.
  • March 27, 2023
thomastupuivao
This has worked!!! thank you so much!! awesome
