I am trying to extract a PDF attachment from an ArcGIS Online feature layer and write it to another online program using the HTTPCaller. (I can do so with CSV attachments.) I can see the PDF is being read by FME Desktop (2020.1.2.1 - build 20624); it's in the arcgisonline_attachment{0}.data attribute but I'm not able to successfully write the PDF contents to the other program. Other forum posts indicate I should use the BinaryDecoder first but it won't decode using either option - Binary64 or HEX. I get an "Invalid Base64 character '%'" or "Invalid HEX character '%'" error. I tried using no decoder and writing the contents of the arcgisonline_attachment{0}.data attribute to the output location directly but get the following error: Received HTTP response header: 'HTTP/1.1 400 Bad Request: Invalid .pdf file.'. What do I need to get the contents of the PDF in the proper format so I can upload it?
- Home
- Forums
- FME Form
- Transformers
- How to extract PDF attachment from ArcGIS Online and upload to online location with HTTPCaller?
- November 12, 2020
- 9 replies
- 262 views
- Contributor
- 66 replies
- Safer
- 158 replies
- November 25, 2020
Hi @aaron , I did some testing with this today and it did take a fair bit of trial and error to sort out how to get the results from the ArcGIS Online Reader into a useable encoding, but I did manage it. Here's what I did:
- Used a BinaryEncoder first to convert from the original Binary format to Base64
- Then, I connected a BinaryDecoder to that to go from Base64 to System Default (fme-system) encoding (I tested on a Mac, so I suspect 'system default' might mean something different on different operating systems)
- From there, I was able to write the PDF directly to my file system using an AttributeFileWriter
I haven't tried using the output from the BinaryDecoder directly in an HTTPCaller though, so I'm not completely sure if that will work. If it doesn't, one option might be to try writing the pdf to a temp folder first, then upload it from there via the HTTPCaller.
Hope this helps!
- Author
- Contributor
- 66 replies
- December 15, 2020
Hope this helps!
Hi @lauraatsafe , thanks for testing. I was able to get it to work without the BinaryDecoder or BinaryEncoder. All I needed to do was set the Target File Encoding parameter to Binary (fme-binary) in the AttributeFileWriter rather than use System Default (fme-system). I also tried your method and that worked too so nice to know there are options. Now on to the HTTPCaller!
I think I may have discovered a bug in both the BinaryEncoder and BinaryDecoder. If I go with the default where "Encode to Different Destination Attributes" is checked and enter an attribute name (or go with the default name) in the "Destination Attribute(s)" text box, that attribute name does not appear in the next transformer so I can't select it. Does this happen with you? I am using FME Desktop 64-bit b20624.
- Safer
- 158 replies
- December 15, 2020
Hi @aaron, Ah! I had a feeling I might have overcomplicated things in my solution! The AttributeFileWriter option you used is definitely a more elegant solution for this.
As for the bug in the BinaryEncoder/Decoder, I'm seeing the same behaviour in build 20806 (2020.2). I'll report that internally to get it fixed. The destination attribute should be exposed automatically. Thanks for reporting this issue!
UPDATE: This issue is being tracked internally as FMEENGINE-59756
- Author
- Contributor
- 66 replies
- January 5, 2021
Hope this helps!
Hi @lauraatsafe , I have hit a roadblock trying to upload my ArcGIS Online PDF to another online program using the HTTPCaller. I keep getting an "Invalid .pdf file" response. I think the issue lies with the way the HTTPCaller is encoding the content because if I "Upload From File" (saved to laptop first) it works but "Specify Upload Body" (directly from ArcGIS Online) does not. It's worth noting I can save the PDF from ArcGIS Online using the AttributeFileWriter, which lets me set "Target File Encoding" to "Binary (fme-binary)" while the HTTPCaller gives me no such option. Is there any way I can set the encoding to "Binary (fme-binary)" in the HTTPCaller? Or maybe another option? I could, as you mention above, save the file first and then upload it, but it's not an ideal workflow so I'm hoping for a better solution.
- Safer
- 158 replies
- January 6, 2021
Hi @aaron , Unfortunately, we don't have a way to set the encoding to Binary (fme-binary) directly in the HTTPCaller. But, I had some success with using my BinaryEncoder/BinaryDecoder trick from my first response to change the attribute containing the PDF binary from fme-binary to something compatible with Binary (application/octet-stream) in the HTTPCaller.
For this, I just fed my arcgisonline_attachment{0}.data into a BinaryEncoder with Encoding Type = HEX and Encode to Different Destination Attributes unchecked (to avoid the bug where the new attributes aren't exposed). Then I passed that newly encoded attribute into a BinaryDecoder with Encoding Type = HEX, Decode to Different Attribute unchecked and the Character Encoding for Output Data set to System Default. In the HTTPCaller, I then set the Content Type for that data to Binary (application/octet-stream) and the API I tested against was then able to recognize the PDF file.
- Author
- Contributor
- 66 replies
- January 6, 2021
Hi @lauraatsafe , using the criteria above I was able to upload the attachment but it comes out corrupt when I download it from the destination online program. (The status code returned from the HTTPCaller was 200.) What's odd is I can write the AGO attachment to a file first and then upload the file with the HTTPCaller and it works fine. I did notice that during translation the file that comes out corrupt is about 2.9 MB while it's only 1.9 MB when uploaded from file. That leads me to believe the same data is being written differently by the HTTPCaller when using Specify Upload Body and Upload From File. Just to make sure I understand clearly, you were able to upload your AGO attachment and it was fine (i.e. - not corrupt) on the other end?
- Safer
- 158 replies
- January 7, 2021
Hi @aaron , ah, yes, Sorry! I actually see the same problem too. My original testing consisted of just making sure that the POST request was successful when uploading the PDF, then checking that the file was there. When I download and open that PDF it is corrupt and the file size isn't right (same as what you see). I'll do a bit more digging to see if there's a way to get this to work, but I'm starting to suspect that saving the file first, then uploading it might be the best option here.
- Author
- Contributor
- 66 replies
- January 7, 2021
Thanks for confirming the corrupt file, @lauraatsafe. I agree saving the file before uploading may be necessary for now. I'm going to pursue that work-around but let me know if you discover anything of note. I appreciate your help!
- Contributor
- 27 replies
- July 31, 2023
Old thread I know, but I came across this issue too (writing corrupt pdf's from an attribute retrieved using HTTP caller). I ended up using python to create the file directly from the attribute:
# Your Base64 encoded PDF string
data = feature.getAttribute('Stream')
outputFilePath = feature.getAttribute('OutputFilePath')
# Decode the Base64 string
decoded_data = base64.b64decode(data)
# Create directory if it does not exist
directory = os.path.dirname(outputFilePath)
if not os.path.exists(directory):
os.makedirs(directory)
# Write the binary data to a PDF file
with open(outputFilePath, 'wb') as f:
f.write(decoded_data)
self.pyoutput(feature)
Related Topics
Duplicated user filters in interfaceicon
Interface DesignerRestricting interface filter element so one client cannot view other client dataicon
Interface DesignerMoving an Interface to A Different Groupicon
Interface DesignerSearch results on Interface aren't accurate
Interface DesignerNew Filter / Record Duplication Behavior (Error)
Interface Designer
Helpful Members This Week
- nielsgerrits
24 votes
- takashi
21 votes
- hkingsbury
18 votes
- danilo_fme
13 votes
- crutledge
13 votes
- oskar
10 votes
- mygis
7 votes
- AliAtSafe
6 votes
- virtualcitymatt
6 votes
- redgeographics
6 votes
Community Stats
- 31,105
- Posts
- 117,929
- Replies
- 38,858
- Members
Latest FME
Scanning file for viruses.
Sorry, we're still checking this file's contents to make sure it's safe to download. Please try again in a few minutes.
OKThis file cannot be downloaded
Sorry, our virus scanner detected that this file isn't safe to download.
OKCookie policy
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
